Date:    2-18-2016
Number of Hours:    2.00
Brief Description:    Started riveting roll bar (24-02)
This went a lot smoother and started riveting the outside of the roll bar while it was clamped in place. I used my steel hole fixture around the mandrel to keep the rivet flush and clean (no burr pull through). A couple rivets I had to drill out, since it looked they were still not flush and smooth. I also torqued the bolts to attach the bases. I ended up buying a HF toque wrench that covered everything the small wrench couldn't.
