Date:    1-8-2016
Number of Hours:    2.00
Brief Description:    Side skin prep (23-05)
Completed cutting the wing slots and was pleased with how it turned out. I started by removing the blue film from around the slot and marking the correct side to remove. Then I taped it up to limit scratches and make it easier to distinguish the line. Then I supported the side skins with 2x4 underneath. I used the cut-off wheel on the dremmel to cut real close to the line and just took it slow, working my way along the line. I place the 2X4 directly under my cut so it wouldn't try to grab as I cut through and just cut into the wood as well. I ended up with a fairly smooth cut near the line which I finished up with a file and used an old scotch bright wheel to hand work the edges smooth. Very happy with the results...hopefully the wing spar will slide in nicely.
