Date:    12-22-2015
Number of Hours:    4.00
Brief Description:    Fwd Tunnel Assembly (22-02)
Pulled all the parts and started prepping and deburring each part. Like everyone else here I'm amazed at how much is supposed to happen on this one page with only a couple pictures. I can't remember how many times I had to read and re-read each instruction in order to get the full meaning. Anyway proceeded here to counter sink the tunnel side panels, but everything I tried wasn't very secure, until I attached a 2X2 to the top and then attached the other end to the wall. I cut a slot in one end and a screw on the other and was able to use this for both the left and right panels. It worked well and was very secure while machining the countersinks.
