12-10-2015 |
3.00 |
Attach bottom skin (21-16) |
Dimpled and attached the nut plates. The Big Squeeze had a little trouble fitting in to squeeze the rivets, but I had the inserts set so that the squeeze point was in the center of the U-shape. It worked better when I switched so that the squeeze point was off center from the U-shape. A lot of clecos...my hand is remembering the wings all those clecos. |
