Date:    12-5-2015
Number of Hours:    3.00
Brief Description:    Fuselage corner skins (21-15)
The pictures don't show much, but that's because all the work is in the prep. Smoothing the edges with the file, breaking the edges with the file (using the small fine rat tail file to get in between the tabs), reaming the holes, deburring the holes, scotchbrite wheal to the edges, scotchbrite pad to the inside surface, acetone, prime and finally attach. The plans call out to rivet in two places the F corner piece, but I don't know how the next skin will overlap later in the build. I'm guessing this is just to hold the corner pieces in place and will have to be removed and replaced later. Other than that, everything went fine.
