Started back on the fuselage today section 21 Mid Fuselage. I prepped the baggage floor, but only primed the underside. I left the top side bare, thinking that I will be painting the interior and I wanted to get a stronger bonding primer. I'm still researching plans for the interior and debating on if I want to tackle painting it myself, but decided to move on with the build. Attaching the floor was tricky since the rivets are so close to the edge. I really had to flex the corners in order to get the squeezer in position. It turned out good and took the opportunity to get a selfie as well.
