6-6-2015 |
5.00 |
Right Flaperon assembly (18-05) |
The technique to drill the holes worked nicely and lined up very well. I started with the punch to mark the holes, then followed with a 3/32 drill bit in the drill press (using the vice clamp to hold it level), then finished drilled with the #30. Everything primed and skeleton assembled. |
