Date:    3-14-2015
Number of Hours:    6.00
Brief Description:    Right Wing Tip underside (17-06)
Again spending a lot of time at work, but found a little time here to make some progress on the wing tip. I spent quite a good amount of time trying to get the fluting just right on the wing tip rib to get it to lay in there without too much flex on the skin. It's challenging to get it to fit just right...in the end I settled for close enough. Also spent a lot of time deburring the underside wing tip skin as well as cutting out new triangles in prep for the tab bending.
