Started work on the wing tip today. Directions call out to bend the handle into shape. It worked out ok, but I think on the right wing tip I'll try to make sure it lines up with the holes in the skin. These lined up for the most part except for one spot next to the bend. I should have made the bend a little tighter radius. The cut out for the wing tip light turned out great. Nice and smooth. I did some research on the epoxy/flox called out on the directions. Looks like I need to place an order with Aircraft Spruce. I've done fiberglass work before, but I'm not familiar with this process.
