Date:    12-6-2014
Number of Hours:    2.00
Brief Description:    Stall Warning attachment (16-03)
Stall waring switch installed. I had Cyndi help me be my eyes as I reached up into the access panel to tighten the switch in the proper position. I also ran the wires to the connector and attached the pins. At this time it also recommends to run wires for the light kit (section 40-05). I want to label the wires, so I ordered online some clear shrink tubing from Grainger.
I've been skipping around in the manual, so I'm starting to make the sections that I've not completed everything (final assembly of the tail section, right wing, etc)
Update 12/13/2014: FYI, when you order shrink tubing for 18 gage wire, it doesn't account for the insulation around the wire. So I ended up placing another order with Del City. I ordered 1/8" and 3/16" diameters hoping that one of these will work.
