Date:    8-16-2014
Number of Hours:    2.00
Brief Description:    Trim Servo Molex connections (11-07)
Finally had a few hours to work on the pin connectors. As I was doing some trial fits I noticed the tool was too thick to only crimp down on the inner set of tabs on the pin. After watching a few videos I realized I needed to thin down the cross section. The bench grinder worked great, so I just kept taking off material until I met the tab thickness for the small Molex pins (not sure what size these are of the size of the wire, but it's small. Everything went well and it's all connected. Although I did lose a cotter pin...somewhere. I'll replace with something at the hardware store for now and maybe throw in some replacement cotter pins with my next order.
