Date:    6-21-2017
Number of Hours:    1.50
Brief Description:    Wall Penetrations and Structural Passthroughs
Began routing the SafeAir1 Air Kit Pitot/AOA plumbing lines through the LH wing rib roots' designated holes. Used one snap bushing per hole, per line.
Installed Larry Larson's plumbing bracket to routeand secure plumbing lines aft of the aileron bellcrank and away from any interference, achieving a clean-looking installation with enough clearance under bellcrank bushing.
Routed Stall Warner wire to avoid interference with aileron pushrods. Semi-installed bellcrank assembly for test-fitting.
