Date:    7-18-2012
Number of Hours:    1.30
Brief Description:    Fitting and Riveting Stiffeners to Rudder Skin
Finished riveting the R-815 (LH) stiffeners onto the R-801PP rudder skin (LH side).
One hole was damaged by a cleco. It was decided to enlarge the hole to 1/8", deburred, sanded, and dimpled to final size.
It's respective stiffener hole was also enlarged to 1/8", deburred, sanded, and dimpled.
Aluminum RTV was applied on hole and stiffener matching area. Then an AN426AD4-4 (1/8") flush rivet was used in place.
Other two holes slightly damaged by clecos where deburred and sanded to avoid creases and/or cracks. Aluminum RTV was olso used in this holes and between skin and stiffener.
