Date:    6-14-2012
Number of Hours:    0.80
Brief Description:    Riveting Horizontal Stabilizer
Riveted HS-404 (LH & RH) and HS-405 (LH & RH) to FSA.
Offset rivet set used so ribs where flexed out of the way as little as possible in order to reach rivets.
Skelleton was re-primed the following day to protect the rivets and damaged primer areas by the riveting process.
