Date:    3-25-2012
Number of Hours:    1.90
Brief Description:    Drilling the Horizontal Stabilizer (RH)
Chose RH HS-702 FSA, HS-603PP RSA, HS-706, HS-707, HS-708 ribs.
Clecoed HS-702, HS-603PP spars with HS-706, HS-703 and HS-708 ribs together according to Plan View and EIV.
Drilled all ribs to spar attach holes with #30 drill (except HS-708 to HS-603PP)
Un-clecoed, deburred holes, cleaned out chips and reclecoed.
Clecoed on HS-810PP skin to skeleton.
Enlarged aft flange of HS-708 rib to HS-603PP to #21.
Marked skin holes to HS-404 and HS-405 ribs using HS-810PP skin holes as guide for approximate position.
Removed and flutted HS-404 and HS-405 ribs, with flutes between holes.
