Date:    2-5-2019
Number of Hours:    1.00
Brief Description:    SB16-03-28 (RH)
Worked on RH SB16-03-28: match-drilled parts, cleaned and primed.
Also cut off both bottom corners of back plate angles to avoid rivet interference when installing bottom skins.
