1-11-2019 |
3.00 |
Flaps (RH) |
Cleco-clamped RH FL-706B and FL-706A together in order to match-drill FL-706A flanges using FL-706B as guide, using detail in DWG 14B and noting edge distances. Bent FL-706B, clecoed it to FL-704R and FL-706A. Match-drilled holes on FL-704R rib and elnarged nutplate hole to 1/4" on FL-706B angled back plate and FL-704R rib per instructions. Drilled holes for nutplate. Match-drilled aft flange of FL-705 ribs (4 places) #40 and then enlarged to #30 using FL-802PP-1 "rear spar" as a guide. Match-drilled #30 FL-803PP-1-R spar using FL-706A angle as a guide. |
