Date:    6-22-2018
Number of Hours:    5.00
Brief Description:    Fuselage Kit Inventory
Inventoried all items of Fuselage Kit.
This process took a total timespan of about 4 months.
After detailed examination and classification of all parts, two things where noticed:
F-800 has one "figure-8" hole pre-punched on it.
F-812C-1 is missing, while two F-812A-1 were accounted for, instead of one.
Will later determine if a call to Van's is required for warranty or just placing a new order for these items is enough.
Everything else was found in good shape, classified and wrapped in their respective sub-kits according to inventory list.
Extra items ordered were inventoried and no parts were missing.
Sub-kits were then reorganized and stored away for further use. All solid rivets, pop-rivets, nuts, washers, and misc. hardware were then classified and orginized into small containers and dividers properly labeled in the shop.
Fuselage Kit comes with Construction Manual and Blueprints to be most current as of Jan. 16, 2018.
