Date:    2-21-2019
Number of Hours:    2.60
Brief Description:    Attaching Ailerons to the Wing (LH&RH)
Worked with both W-816 pushrods.
Deburred all holes inside and outside, including those in VA-111 threaded rod ends.
Primer all mating parts and riveted them together using MSP-42 blind rivets covered in JB Weld 2-part steel epoxy for added safety.
Applied a layer of primer to both pushrods and riveted VA-111 assemblies.
Set aside to let epoxy cure and primed the complete lenght of pushrods.
