Date:    1-19-2019
Number of Hours:    1.50
Brief Description:    Wingtip Wiring (LH&RH)
Worked on LH & RH wingtip wire management. Decided to install a K1000-4 nutplate with pop rivets on the outboardmost W-712R & W-712L wing ribs web, in order to install a 5/16" cushioned adel clamp, secured by a AN4-6A bolt and a AN960-416 washer. This will hold the wires exiting from the electrical conduit in each wing. Secured wire bundles with Breyden Lacing string intervals.
