Date:    10-9-2015
Number of Hours:    2.00
Brief Description:    Working with Plexiglass Lens (RH)
Made a "handle" using Gorilla tape for the lens and lap the tape over the lens top and bottom edge, and sticking the tape inside the lens.
Slid the lens into te hole by slightly sqeezing it. Snuggly pulled the lens out into the hole with the Gorilla tape.
Using the LE holes as a guide, match-drilled #40 the the plexiglass and held in place with clecos.
Enlarged the holes to #30 and installed clecos. Removed the lens from the Leading Edge.
