10-17-2014 |
1.20 |
Assembling and Sealing the Tank (LH) |
Wet-riveted the T-405 tank attach angle and T-410 reinforcing plates in place on the end ribs. Wet-riveted nutplates around reinforcement ring on inboard rib and covered nutplates with sealant. Made fillets of sealant at the joints of all mating surfaces of access panel reinforcement ring, T-405 and T-710. Covered the aft tooling hole on the outboard T-703 end rib plugging in an AN470AD6 rivet and proseal. Left parts to dry. |
