9-1-2014 |
3.40 |
Fitting Attach Angles to Spar and Baffle (RH) |
Match-drilled #40 all rivet holes attaching T-701-R Fuel Tank skin to ribs and baffle secured fuel tank to wing assembly using two rachet-type strap fasteners. Protected rear spar with pieces of wood at the locations where the straps intersect the rear spar. Clecoed all remaining holes that attach Fuel Tank and baffle to spar . Match-drilled #40 any remaining rivet holes attaching T-701-L Fuel Tank skin to ribs and baffle secured fuel tank to wing assembly using two rachet-type strap fasteners. protected rear spar with a piece of wood at the locations where the straps intersect the rear spar. Held down and secured the LH Tuel Tank to the spar and wing skeleton using two ratchet -type straps. Clecoed all remaining holes that attach Fuel Tank and baffle to spar. Match-drilled #19 the W-723 Leading Edge-to-Fuel Tank Joint Plate for 8R8 screws using T-701-R screw holes in skin as guide. Placed 5/32" clecos in each new hole. Disassembled outboard Leading Edge from spar to reveal outboardmost T-703R Tank Rib and its corresponding outboard attachment Z-Bracket. Used Cleco clamps and existing 1/8" holes to secure T-703R rib in place. Match-drilled #30 the 5 holes that attaches the rib to the Z-bracket using the tank rib aft flange holes as a guide with a 12" drill bit with a drill bit stop at the tip to avoid accidental drilling into the spar. Final drilled the remaining holes in the same rib to #30. Placed clecos in all holes to secure the rib and baffle to the z-bracket. Repeated the step above on the inboardmost T-703L tank rib with the holes not previously match-drilled. Removed T-701-R Fuel Tank Skin and all ribs except for the outboard T-703R and the inboard T-703L fuel tank ribs which kept the T-702 Tank Baffle in place. |
