9-29-2014 |
0.60 |
Fuel Tanks Return System (RH) |
Drilled hole in the respective RH fuel tank ribs to install the Fuel Return Line fitting and tubing if ever required for the use of a fuel injected engine with unused, high-pressure fuel return system to fuel tank. Hole and fitting will be the same as that used for the flop tube assembly on the inboard rib, and smaller on the next two bays. |
