6-6-2014 |
0.50 |
Fuel Tanks Return System (LH) |
Drilled a hole in the LH fuel tank end inboard rib to install the Fuel Return Line fitting if ever required for the use of a fuel injected engine with unused, high-pressure fuel return system to fuel tank. Hole and fitting will be the same as that used for the flop tube assembly. |
