7-1-2014 |
0.80 |
Wire, Switches, Fuses, and Connectors (LH) |
Worked on electrical wiring in LH wing. Drilled holes and installed nylon adel clamps to outboard LH LE rib to hold duckworks HID LE landing light ballast wires: Drilled two #19 holes 1.0" inboard from LE skin and 1.0" distance (front hole) from stiffening crease and (aft hole) from main front spar. |
