5-27-2014 |
1.50 |
Fitting the Tank Skin to Ribs and Baffle (LH) |
Clamped the T-411 cover plate on the rib with the flat forward edge aligned with the stiffener bead (at .453"), and aligned to the top and bottom rib flanges (.360"). Drilled all of the screw holes using T-411 cover plate as guide. Clecoed the cover plate in place. Clamped the T-405 and T-410 reinforcing plates in place on the end ribs and drilled the attach holes. Fabricated LH & RH T-714 Fuel Vent Line clips from scrap aluminum pieces. |
