6-5-2014 |
1.00 |
Installing Capacitive Fuel Quantity Sender (LH&RH) |
Cut two pieces of 18 AWG wire to 15". Stripped one end of each wire and soldered to the LH & RH BNC bulkhead connector, respectively. Used heatshrink for added protection and applied a coat of sealant to final seal the exposed soldered ends of the BNC terminals and wires, so no exposed bare wire or solder is exposed. |
