Date:    11-11-2013
Number of Hours:    0.70
Brief Description:    Installing Stall Warning System
Final-drilled #10 both stall warning guide holes in the Leading Edge Skin.
Marked with sharpie two lines connecting both edges of the holes and removed the material between the holes and lines with Dremel tool.
Deburred, filed, and sanded the edge for a smooth and uniform finish.
Separated the VA-196FG Mount Bracket into VA-195F for the RV-8 installation.
Final-drilled #40 the rivet holes in the flanges of the Mount Bracket, deburred, dimpled, cleaned and primed before installation.
