3-21-2008 |
2.10 |
Forward Spar and Rudder Stop/Striker Plate |
1.) Dimpled the flanges of the Forward Spar. 2.) Took awhile to find the Rudder stop and striker plates, found them and debured the edges and filed to smooth. 3.) Final drilled the Forward Spar doubler, debured the holes. 4.) Final Drilled the Rudder Stop to Top hinge of the Bottom Rudder hinge brackets as per plans. 5.) Debured Rudder stops and clecoed to rudder hinge bracket. Completed Steps 4 5 and 6 on page 6-4. Or simply put riveted teh R-1007B Rudder stops to the VS-1010 Rudder Hinge Bracket. |
