Today I worked on the door hinge covers for the interior. I layed-up the pax side door and have both doors covers installed and a first pass at fairing it in with filler. I also installed an air splitter in the oil cooler box that is recommended by the oil cooler manufacturer. Because of the crappy design, the vendor doesn't believe that enough air is getting to the top of the cooler causing a loss in effective cooling capacity. the splitter is intended to force some additional air to the top of the box. I didn't like that the thing was basically mounted only on the bottom whcih left the top half to vibrate which would eventually lead to failure so I rtv'd the whole length which should immobilize it for good.
