Date:    8-24-2009
Number of Hours:    1.50
Brief Description:    Door seal area
Spent some time on the pilot side door seal area. I think I have it basically ready to go and the test fit of the seal looks good. The one thing I don't like is the aft end of the door is a bit hard to pull in enought to shut now. This can be a problem given the problems with doors going off in flight because of missed door pins when closing. Fortunately the door pin blocks that are aftermarket make it very obvious that the door isn't in. I may still try to put a strap or something back there to help pull it in.
