I wanted to get a half way decent days work in today so I bounced around a bit working on different things. First thing I did was continue the battery cable run through the spars now that I had a good idea where to run it without any interference. I also installed the new flex lines for the brakes. Most of the time was around working on connecting up the controls and various actuation. The sticks are in and the push pull tubes are all in place. Tomorrow I will start work on installing the TruTrak servo and finishing up the elevator connections.
