6-29-2006 |
2.00 |
Ran the rudder cables |
This morning I installed the rudder cables. Not the easiest of things to do when you are a big guy as it requires a lot of work in very tight places. Surprisingly it went some what quickly with no major problems. I also opted to use cable fairings that you can get from Avery or Cleaveland to dress up the exit points. I used a combination of MK-319-BS rivets and my favorite E6000. When I finish the aircraft I will fair it all in with a little bondo. |
