I started on the rudder control system this morning but didn't really make a large amount of progress because of the alodine and painting. The pedal mounts come powder coated but the pedals need to be assembled and are just unpainted aluminum. So I got the pedals all ready to go and started to paint them. Because these will be visable, and under a far amount of wear, I decided to paint them. I am using an industrial version of Rustoleum and it works pretty good. This is the same stuff I used behind the flap gap seals. Once they dry overnight I will paint the other side of them. I also painted the brake reservoir white. Man I wish this program had spell check!
