4-27-2006 |
2.00 |
Continued fabricating the aft ski rack mounts |
I'm continuing on with building the aft ski rack mounts. The Home Depot aluminum angle is some serious crap but it will do the job for this. After bending the angle into a rectangle I also riveted a gusset in the four courners. The narrow end will sit just slightly proud of the bulkhead and be rivited in place. I also put dome double "D" weatherstriping aound the inside for additional cushion and the glued it in place with E6000 to make sure there would be no way it could come off. |
