Date:    3-8-2006
Number of Hours:    1.50
Brief Description:    Baggage door shims, redo of Ch 26 stuff.
As I was fitting the side skin again I was having a problem getting holes to line up near the spar. I took the skin back off and looked around for where the problem may lie. For some unknown, dumb ass reason, I put the tabs on F1015-A and F1018 on the outside of the corresponding uprights which was putting just enough bow into the skin to cause my hole problem. I have no idea how I managed this as it's painfully clear how it should have went. So to fix, I need to drill out most of the rivets holding those two ribs in place and put it in correctly.
