Date:    5-7-2008
Number of Hours:    2.50
Brief Description:    Replaced brake lines
So a while back I found out that a company out of cali called Bonaco was making some real nice brake lines to replace the ugly/whimpy plastic lines around the rudder pedals. I generally feel that brakes are important so I decided to order a set. These are very high quality teflon with stainless braid and a nice vinyl anti chaffe sleeve. Very glad that I went with them. Direct replacment for all the lines and fittings around the pedals and also a set to go down the gear legs. Installation really didn't take much time. If you are interested in a set contact brett@bonacoinc.com. I also did some generally messing around with some other outstanding things like the parking brake. I need to find a way to mount a regular push/pull lever to actuate the lever on the P-break. It would be easy if the lever operated 90 degrees to the unit itself but it really operates between something like 115 and 65 which means I cant just come off the p-brake mount like others have done or I might not have enough actuation to actually lock the brake. I'll get that figured out later. I'm also looking at what things can be/need to be done so I can get this thing on it's gear and get the engine hung.
