Date:    10-29-2005
Number of Hours:    3.00
Brief Description:    Finished 4 of 7 Emp fairings
Got most of the fairing work done. Several are attached and the remaing three are at least prepared. The rudder and VS fairings are still unattached because of the tail light and camera respectively. I can't set the camera until the emp is attached to the fuselage and I still need to figure the routing of the wire for the tail light.
I'm not too happy with the intersection between the HS and elevator fairing on the right side. I went at it with the bandsaw without really thinking about the curve between the two. It will still work but it may be easier just to get a replacment. I'll check the cost.
