10-15-2005 |
1.00 |
Mounted control unit for pitot |
One of the things about the pitot I'm using is that it is actually thermostaticaly controlled. Because of this there is a small control unit that needs to be mounted near the pitot itself. Good thing I decided to move the pitot so far to the outboard part of the wing otherwise I would have need to put in an access panel for this. Instead it only took an hour to throw together a little bracket. |
