Date:    8-7-2014
Number of Hours:    7.00
Brief Description:    Electrical prep and brake lines
Finished brake lines on rudder assembly. Drilled ground block on firewall. Prepped for conduit run up firewall. Drilled in transponder mount. Temp mounted adahrs so i could cut static lines. CS slide rail for the canopy.
