Date:    8-13-2013
Number of Hours:    6.00
Brief Description:    Fuel tank attach bracket. Started on rudder pedals
Started making new shims for fuel attach bracket because I screwed one up while drilling. New ones are now successfully drilled. Drilled bottom screw hole to size. I'm unsure how to continue because I do not know of to dimple the holes for the three flush rivets. CS? Cleaned edges on brackets. Primed and painted. Started working on rudder pedals.
