5-31-2008 |
6.00 |
Transponder antenna and wing root terminal strip |
Started out today by drilling a 1/2" hole for the transponder antenna. Crimped the male coaxial cable to the transponder end of the cable. Next, crimped the coaxial bulkhead fitting for the ILS/LOC/NAV antenna wiring at the right wing root. Finished up the day by fabricating 2 mounting brackets out of .032 aluminum for the other wiring that needs to be detachable at the left and right wing roots. |
