Date:    3-2-2009
Number of Hours:    9.00
Brief Description:    Cowl flap fiberglass work
Cut the cowl flaps away from the cowling. Spent a bunch of time with a dremel with a 60-grit sanding drum "hogging" out the inner layer of the pre-preg (honey-comb) structure on the cowling to leave the thin smooth layer of outer glass in tact. Will do the same on the cowl flaps tomorrow.
