Date:    2-23-2009
Number of Hours:    6.00
Brief Description:    Fabricate cowl flap mechanism
Riveted the two bearing assemblies together, and drilled the location of each to the firewall. This served to provide the dimensions of the steel tubing that will run horizontally 5 inches from the lower firewall edge. Cut the shaft to length and inserted the threaded inserts and clecoed to the firewall for a test fit. Also cut and drilled the UHMW block that will support the center of the shaft during rotation (Note: Spoke with Van's about the use of UHMW on the (engine side of the) firewall, and they saw no problem with this).
