Out of 3/4 in plywood, I created a prop disc 13 inches in diameter with the bolt holes on a 4 and 3/8 inch diameter from center. The disc is the same diameter as the Prop spinner and is necessary to properly locate the top and bottom cowling halves in relation to the spinner. And this is necessary (at this point) in order to locate a rough position of the GPS tray on the firewall so that the GPS antenna's are as high as possible without touching the inside of the cowling. ...One thing leads to another.
