Continued with the coaxial cables. Not too happy about wasting 3 female coaxial ends due to mis-crimping the pin... I have just enough to finish this bit of work, so no real harm done. Going to have to put in an order for parts soon... Spent some time working on the mount for the Prop controller and the Throttle cable. I moved one of the switches down to the Prop Contrller mount to mount the Throttled cable in the main panel just where you would want it. Also found that the Wet Compass will go in the spot originallly intended. This due to there's a pair of adjustment magnets to cancel out any minor deviation from the airframe. I'm able to adjust it perfectly -- cool!
