Date:    9-23-2007
Number of Hours:    8.50
Brief Description:    Fitting the canopy frame
Fit and drilled the C-704 splice plate to the F-631A's. Did the layout for the rivet pattern on the angle bracket welded to the aft end of each Wd-725. At this point, it was decided to rivet this frame together for good. Now, the canopy frame is one piece but still has some minor amount of flex that should *mostly* be removed when attaching the plexiglass.
