Date:    2-7-2008
Number of Hours:    2.50
Brief Description:    Primary wiring forward of firewall
Completed the wiring for the Oil Pressure sender and the Oil temperature sensor. There is a small area behind the Oil Filter mount in which to run a high-temp 1/4 split loom. I'm happy with the wiring and believe it will withstand the heat in that area.
