Date:    1-28-2008
Number of Hours:    2.00
Brief Description:    More firewall pass-thru's
Located the eyeball swivel that will pass the throttle cable through the firewall. Needed to do this so I could locate the manifold pressure unit for the EIS 4000. Need to locate this so I can later locate the large hole for the engine wire loom. ...And I need to locate that so I can later locate the terminal strip for the engine wires on the inside of the firewall. One thing leads to the next...
